JoWa Postad December 2, 2008 Dela Postad December 2, 2008 Comodo Windows Tweaker 1.0.56160.15 beta 2 BETA 2 is here! It's still a BETA so please do not use it on your production machines but only on test ones.What's new? ---------------------------------------- - All the modules have support for drag&drop; - New applications added to Privacy Cleaner scan engine; - A new and improved scan engine is now implemented in Privacy Cleaner and Disk Cleaner; - Visual Styler features are now available for more windows versions; Known Issues: ---------------------------------------- - Removing all browsers data after a Privacy Cleaner -> Internet scan might make Windows XP SP3 un-bootable; - Changing cursors and icons in Visual Styler might not work if you change windows's theme. Bug Reports: ---------------------------------------- Please use http://forums.comodo.com/diskregistrypriva...s-t31091.0.html to report your bugs. Our moderators collect these bugs and submit them to the devs. BETA NOTICE: This product is intended for special users (BETA Testers) who would like to join the testing process. It may contain major bugs that could cause serious problems and not be suitable for your everyday use yet. Please do not use it in your production machines. Download Locations: ---------------------------------------- Setup for Windows Vista 32-bit, Windows 2003 Server 32-bit, Windows XP 32-bit and Windows 2000 SP4: URL: http://download.comodo.com/cwt/download/se...03_x32_BETA.exe Size: 5.22 MB (5,475,136 bytes) MD5: 517B0577E80D466E303E8ACB0A447A33 SHA1: 6B3917C927DA853F56ED351CEC74D61286A72954 Setup for Windows Vista 64-bit, Windows 2003 Server 64-bit and Windows XP 64-bit: URL: http://download.comodo.com/cwt/download/se...03_x64_BETA.exe Size: 5.91 MB (6,205,144 bytes) MD5: 56F7C11A92FD7542268AB9288309ED15 SHA1: B91EF06368731CC3351319972F335F5D5F414478 Källa: https://forums.comodo.com/diskregistrypriva...d-t31092.0.html Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 3, 2008 Författare Dela Postad December 3, 2008 Fick behålla startmenyn den här gången i alla fall! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 3, 2008 Dela Postad December 3, 2008 Fick behålla startmenyn den här gången i alla fall! Det var ju underbart! Använd inte Check for updates. Den ”uppdaterade” min installation till förra versionen! ??? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 3, 2008 Författare Dela Postad December 3, 2008 Och efter en omstart var man utan Startmeny igen! > Nu struntar jag i den här! :'( Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 3, 2008 Dela Postad December 3, 2008 Och efter en omstart var man utan Startmeny igen! > Nu struntar jag i den här! :'( Hm… After I installed it said it found an update and automatically reinstalled the old version. Also my start menu no longer appears. Reinstalling 1.0.561.15 and declining to update and restarting fixes the start menu. https://forums.comodo.com/diskregistrypriva...23555#msg223555 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 3, 2008 Författare Dela Postad December 3, 2008 Mjoo... jag gjorde en health check och en av komponenterna var korrupt, när jag reparerade så drog den troligen ner nåt gammalt! ??? Den här får dom allt jobba på ett tag innan man kan använda den! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 3, 2008 Dela Postad December 3, 2008 Mjoo... jag gjorde en health check och en av komponenterna var korrupt, när jag reparerade så drog den troligen ner nåt gammalt! ??? Den här får dom allt jobba på ett tag innan man kan använda den! Jo, det är ju syftet med beta-testning… “Health check”, Diagnostics alltså? Gjorde du det innan du rensade? I så fall har du väl inte testat beta 2… Jag har i alla fall en healthy installation och inga problem med startmenyn. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 3, 2008 Författare Dela Postad December 3, 2008 Självklart är det beta2... går inte att få till en "healthy installation" här (Vista x64)! ctm.exe är och förblir korrupt, det är när jag försöker reparera som det skiter sig! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 3, 2008 Dela Postad December 3, 2008 Självklart är det beta2... går inte att få till en "healthy installation" här (Vista x64)! ctm.exe är och förblir korrupt, det är när jag försöker reparera som det skiter sig! ctm.exe är Comodo Task Manager. Komponenterna är ju oberoende av varandra, så om du ignorerar ctm.exe, borde du kunna använda övriga komponenter utan problem. Du kan också välja bort Task Manager vid installation. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 3, 2008 Författare Dela Postad December 3, 2008 Självklart är det beta2... går inte att få till en "healthy installation" här (Vista x64)! ctm.exe är och förblir korrupt, det är när jag försöker reparera som det skiter sig! ctm.exe är Comodo Task Manager. Komponenterna är ju oberoende av varandra, så om du ignorerar ctm.exe, borde du kunna använda övriga komponenter utan problem. Du kan också välja bort Task Manager vid installation. Jag känner till det.... det var liksom inte poängen! Jag har deltagit i tillräckligt många utvecklingsprojekt, både stängda och publika, för att ha uppfattningen att man bör testa en beta med så här uppenbara buggar internt! Risken är stor att programmet får ett oförtjänt dåligt rykte om man släpper det publikt när det t.o.m innehåller kända fel! Jag är säker på att det inte skulle vara några problem att få ihop ett bra testgäng via Comodos forum! Men, men... jag är ju inte engagerad i detta projektet, så jag kan ju bara skippa programmet! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Bowmore Postad December 3, 2008 Dela Postad December 3, 2008 Med tanke på vilka problem de har med att fixa uppdateringarna för av-databasen till CIS så skulle jag nog vänta tills programmet blir officiellt testat. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 9, 2008 Dela Postad December 9, 2008 Dags för en ny version igen, 1.0.57970.16 RC 1. Dessutom nytt namn: Comodo System Cleaner istället för Comodo Windows Tweaker. COMODO Windows Tweaker is now a Release Candidate 1! Also we rebranded the application... and now it's COMODO System Cleaner. Realease Candidate is to be tested same as a BETA version!!! Please do not test it only on test machines... not production or home computers. What's new? ---------------------------------------- - New applications added to Privacy Cleaner scan engine; - A new and improved scan engine is now implemented in Privacy Cleaner and Disk Cleaner; - You can now uninstall applications from System Information. What was fixed ---------------------------------------- - Disk Cleaner compatibility issues with windows SP3; - Visual styler works better on all windows Versions; - System block problem in Privacy Cleaner. Known Issues: ---------------------------------------- - Running Registry Cleaner and Disk Cleaner in the same time may cause problems. Bug Reports: ---------------------------------------- Please use http://forums.comodo.com/diskregistrypriva...s-t31448.0.html to report your bugs. Our moderators collect these bugs and submit them to the devs. BETA NOTICE: This product is intended for special users (BETA Testers) who would like to join the testing process. It may contain major bugs that could cause serious problems and not be suitable for your everyday use yet. Please do not use it in your production machines. Download Locations: ---------------------------------------- Setup for Windows Vista 32-bit, Windows 2003 Server 32-bit, Windows XP 32-bit and Windows 2000 SP4: URL: http://download.comodo.com/csc/download/se...003_x32_RC1.exe Size: 4.35 MB (4,568,784 bytes) MD5: CB7BF9EBAF9279A60BDE3CCC7BB76B03 SHA1: 4327F5F5DCA7E0540DB053FEBF42E71B27848DC9 Setup for Windows Vista 64-bit, Windows 2003 Server 64-bit and Windows XP 64-bit: URL: http://download.comodo.com/csc/download/se...003_x64_RC1.exe Size: 5.07 MB (5,321,624 bytes) MD5: E5D095866AA2C708880F4EE85B1F6F68 SHA1: 793975EC27A9C248C82B867713A2095311F0E2D3 Källa: https://forums.comodo.com/empty-t31451.0.html;topicseen Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Comodo System Cleaner 1.0.59482.18 kan laddas ned från hemsidan. http://system-cleaner.comodo.com/ Jag har inte sett något om denna version på Comodos forum, så jag vet inte vad som skiljer den från 1.0.57970.16 RC 1, och inte heller exakt när den släpptes. ??? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Kollar den för fullt, men csi.exe ?? ...Comodo System Information?? Står som "Altered" i diagnostiken, och finns heller inte i programmappen, i mitt 64-bitars Vista! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Kollar den för fullt, men csi.exe ?? ...Comodo System Information?? Står som "Altered" i diagnostiken, och finns heller inte i programmappen, i mitt 64-bitars Vista! Finns i min burk, XP 32-bitar. Installationen är healthy enligt Diagnostics. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Ok.... hjälper inte att "reparera" heller.... den är borta! ??? Men, men... dom verkar ha fått någorlunda ordning på resten. Förra versionen var "halva" listan Altered! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Men den installerades och fanns innan du körde Diagnostics? ??? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Men den installerades och fanns innan du körde Diagnostics? ??? Är inte helt säker på det.... jag reparerade när jag såg att den var Altered. Efter reparation ville den starta om burken! Först när jag såg att den forfarande var Altered, började jag undersöka om den fanns/fungerade! Edit: Om inte Systeminformation fungerar, måste man nästan fråga sig hur väl vissa andra verktyg funkar! ...som t.ex System Benchmark Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Om inte Systeminformation fungerar, måste man nästan fråga sig hur väl vissa andra verktyg funkar! ...som t.ex System Benchmark Tja… komponenterna är ju inte beroende av varandra. Å andra sidan förstår jag inte alls hur Benchmark-resultaten skall tolkas. ??? Windows Benchmark.WINDOWS XP Read Keys Test :2288 Read Keys&Values Test :2369 Swap Test :338 Manualen säger inget… Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Comodo System Cleaner 1.0.59482.18 kan laddas ned från hemsidan.http://system-cleaner.comodo.com/ Jag har inte sett något om denna version på Comodos forum, så jag vet inte vad som skiljer den från 1.0.57970.16 RC 1, och inte heller exakt när den släpptes. ??? Nu är det kungjort, men inga tekniska detaljer: https://forums.comodo.com/diskregistrypriva...d-t32244.0.html Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Efter en 3:e ominstallation fick jag äntligen HELA paketet installerat och "Healthy"! : Kan det möjligen vara 64-bitars "setupen" som är lite buggig? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Efter en 3:e ominstallation fick jag äntligen HELA paketet installerat och "Healthy"! : Kan det möjligen vara 64-bitars "setupen" som är lite buggig? Märkligt… ??? Installationen bör väl inte kunna ställa till så mycket. Komponenterna kan ses som helt portabla och fristående program, som, vad jag förstår, endast behöver extraheras ur exe-filen. Borde komma en zip-version också, tycker jag. Fint att du fick allt på plats till slut. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Märkligt ??? Installationen bör väl inte kunna ställa till så mycket. Komponenterna kan ses som helt portabla och fristående program, som, vad jag förstår, endast behöver extraheras ur exe-filen. Borde komma en zip-version också, tycker jag. ja inte vet jag... jag vet bara att jag hela tiden har haft problem med corrupta moduler i CSC x64! Får hoppas den sköter sig nu! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 24, 2008 Dela Postad December 24, 2008 Comodo Task Manager kraschar så snart jag markerar en process. :'( Funkar din CTM, e-son? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
e-son Postad December 24, 2008 Författare Dela Postad December 24, 2008 Funkar din CTM, e-son? Jupp, den inte bara fungerar... den är bra dessutom! ;D Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
