PCGuiden Posted June 2, 2010 Share Posted June 2, 2010 Har köpt detta Mhttp://www.jmedata.se/PartDetail.aspx?q=p:2837803 Som var Fat 32 men jag vill formatera det till NTFS formatet men det funkar inte, vad skall jag göra någon som har erfarenhet... Hur skall jag formatera det? Quote Link to comment Share on other sites More sharing options...
Manneman Posted June 2, 2010 Share Posted June 2, 2010 Har du provat från enhetshanteraren? // Manneman Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 Har köpt detta Mhttp://www.jmedata.se/PartDetail.aspx?q=p:2837803 Som var Fat 32 men jag vill formatera det till NTFS formatet men det funkar inte, vad skall jag göra någon som har erfarenhet... Hur skall jag formatera det? Prova exFAT om alternativet finns. http://www.tech-recipes.com/rx/2801/exfat_versus_fat32_versus_ntfs/ http://en.wikipedia.org/wiki/ExFAT Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 2, 2010 Author Share Posted June 2, 2010 Hur stor skall allokeringsenheten vara då? Får man plats med 4GB+ filer på exFAT Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 (edited) Hur stor skall allokeringsenheten vara då? Får man plats med 4GB+ filer på exFAT "File size limit is now 16 exabytes"...! Hur stor skall allokeringsenheten vara då? Det ger sig självt... eller 32kB...! Edited June 2, 2010 by e-son Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 2, 2010 Author Share Posted June 2, 2010 "File size limit is now 16 exabytes"...! vad är exabytes?? Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 ...dock måste sägas att vissa enheter typ TV/Mediaspelare/Nätverkslagring kanske inte kan läsa exFAT. Windows XP behöver också en specifik uppdatering för att kunna läsa exFAT.... annars är det ett grymt filsystem...! Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 2, 2010 Author Share Posted June 2, 2010 Funkar inte att installera portable apps på iallafall Quote Link to comment Share on other sites More sharing options...
Opptokoppter Posted June 2, 2010 Share Posted June 2, 2010 Yhooo Men En Yottabyte i shottahiiiti Känns som man börjar drabbas av Solsting eller så triggade detta underbara symbolistiska påhiiitade namnet..Vem kan ha funderat ut detta? Aldrig hört talas om de förut Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 Har aldrig provat... men det kan säkert stämma! Själv installerar jag aldrig menyprogrammen... jag använder pinnen som lagringsenhet och bara mappar dom portabla program jag vill ha. En mapp med genvägar till startfilerna kan fungera som "Startmeny"... om man nu måste ha en sådan. Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 Yhooo Men En Yottabyte... Aldrig hört talas om de förut Nää... och du hinner säkert bli rejält gammal innan det blir aktuellt....! ...men påhittat vet jag inte om man kan kalla det.... http://en.wikipedia.org/wiki/Yottabyte Quote Link to comment Share on other sites More sharing options...
Opptokoppter Posted June 2, 2010 Share Posted June 2, 2010 (edited) Roligt & skoja ibland, kunde inte låta bli Skrattade rätt gott här Oh jag som tyckte en miljon lät som tillräckligt, tänk 8 steg högre upp på skalan. Septillion= samma som Yottabyte. Tackar för sidan, kommer spara den för framtida bruk Man vet aldrig hur rik man blir, eller så kan man ju ha glädje av den åt andra hållet Edited June 2, 2010 by Opptokoppter Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 Man vet aldrig hur rik man blir, eller så kan man ju ha glädje av den åt andra hållet Åt "andra hållet" är glädjen begränsad, kan jag säga....! Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 2, 2010 Author Share Posted June 2, 2010 Har verkligen fått ett Måndagsexemplar , man kan inte göra något.... Att installera portable apps applikationen tar på ett annat minne 3-4 minuter medans med det nya minnet tar det 20-25 minuter om det ens blir färdigt .. brukar sluta med att filen x.exe inte kan installeras... Quote Link to comment Share on other sites More sharing options...
e-son Posted June 2, 2010 Share Posted June 2, 2010 (edited) Ta inte illa upp nu men... Har du provat att starta om burken och typ, börja om? Radera/formatera skiten och försök installera när du inte har 68 andra processer igång....! Edited June 2, 2010 by e-son Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 3, 2010 Author Share Posted June 3, 2010 Kan ju inte formatera pinnen ens ... nåja ett nytt försök göres snart Quote Link to comment Share on other sites More sharing options...
PCGuiden Posted June 3, 2010 Author Share Posted June 3, 2010 verkar ha varit någon problem med usb portarna nu funkade det att formatera till NTFS formatet och installationen av Portable apps funkade kanon föra över filer gick bra Quote Link to comment Share on other sites More sharing options...
