JoWa Postad December 20, 2019 Författare Dela Postad December 20, 2019 Libvpx, referensimplementering för VP8 och VP9, har nu släppts i en ny version, 1.8.2. Pekin Duck Release (v1.8.2)https://chromium.googlesource.com/webm/libvpx/+/v1.8.2 Rav1e 0.2.0, AV1-kodare skriven i Rust, har släppts, och är åtskilligt snabbare än 0.1.0. v0.2.0: Yuletide GreetingsImprovements Faster, overall 40%–70% faster than v0.1.0 depending on the encoding settings. Optional serialization/deserialization of the encoding parameters through the feature serialize Optional cli advanced commands to use it. The builds are now using the dwarf debug format for the targets that support it, before it was a mixture of dwarf and stabs due to the nasm defaults. Added a --benchmark hidden flag for the cli for MacOS and Linux. documentation is now available on docs.rs. Changes Segmentation support is now a tunable SpeedSetting and currently it is default off since it can produce desyncs, this does cause a 3% decrease in quality. Fixes #1903 - edge-of-frame miscomputation #1858 - desync on speed 0 and 1 when certain quantizers are selected Known issues #1930 - segmentation encoding may cause desync https://github.com/xiph/rav1e/releases/tag/v0.2.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Februari 12, 2020 Författare Dela Postad Februari 12, 2020 AV1-avkodaren Dav1d 0.6.0 ‘Gyrfalcon’: 0.6.0 is a major release for dav1d: New ARM64 optimizations for the 10/12bit depth: mc_avg, mc_w_avg, mc_mask mc_put/mc_prep 8tap/bilin mc_warp_8x8 wiener cdef New AVX-512 optimizations for prep_bilin, prep_8tap, cdef_filter New SSSE3 optimizations for film grain New AVX2 optimizations for msac_adapt16 Fix rare mismatches against the reference decoder, notably because of clipping Improvements on ARM64 on msac, cdef optimizations Improvements in the C version for itxfm, cdef_filter https://code.videolan.org/videolan/dav1 ... aster/NEWS AV1-kodaren Rav1e 0.3.0 har släppts med följande ändringar:Improvements Faster and better Speed 10 Smaller binaries (Around 3MB stripped on x86_64/Linux) Faster build times (About 14% faster build time) Multi-threaded deblocking filter Additional x86_64 SIMD code More auto-vectorizable codepaths and bounds check elisions ⅙ less memory allocations Improvements on the intra-modes pruning logic in the RDO More float to fixed-point conversions Make an early-exit condition in RDO faster Simplify logic in Counter/Recorder store method Support wasm32-wasi as build target 1–2% overall quality improvement (at speed level 2) New tools Intra edge filter Switch frame support (use -S, --switch-frame-interval <SWITCH_FRAME_INTERVAL> to enable it from the CLI) Fine directional intra prediction Still Picture support with reduced still picture header (AVIF) Changes Upstream nasm-rs 0.1.7 can be used to build rav1e. The C header produced is now C++-compatible Fixes #1930 #2055 https://github.com/xiph/rav1e/releases/tag/v0.3.0 Netflix Now Streaming AV1 on Android (Netflix Technology Blog) Today we are excited to announce that Netflix has started streaming AV1 to our Android mobile app. AV1 [libaom] is a high performance, royalty-free video codec that provides 20% improved compression efficiency over our VP9 [libvpx] encodes. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 8, 2020 Författare Dela Postad Maj 8, 2020 LibAOM 2.0 är på gång. RC1 har släppts: https://aomedia.googlesource.com/aom/+/ ... v2.0.0-rc1 Släppts har också SVT-VP9 0.2.0: Fix ffmpeg plugin “Too many invisible frames” issue for mkv/webm/mp4/dash. Fix video corruption for non-multiple-of-8 gop size. Remove -irefresh-type option. https://github.com/OpenVisualCloud/SVT- ... tag/v0.2.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 19, 2020 Författare Dela Postad Maj 19, 2020 (redigerade) I dag, på WebMs tioårsdag, släpptes libaom v2.0.0 Applejack, en större uppdatering av AV1-referensimplementeringen LibAOM.https://aomedia.googlesource.com/aom/+/refs/tags/v2.0.0 Redigerad Maj 21, 2020 av JoWa Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 21, 2020 Författare Dela Postad Maj 21, 2020 (redigerade) Dav1d 0.7.0 ”Frigatebird” har släppts. Changes for 0.7.0 ‘Frigatebird’: ------------------------------ 0.7.0 is a major release for dav1d: Faster refmv implementation gaining up to 12% speed while –25% of RAM (Single Thread) 10b/12b ARM64 optimizations are mostly complete: ipred (paeth, smooth, dc, pal, filter, cfl) itxfm (only 10b) AVX2/SSSE3 for non-4:2:0 film grain and for mc.resize AVX2 for cfl4:4:4 AVX-512 CDEF filter ARM64 8b improvements for cfl_ac and itxfm ARM64 implementation for emu_edge in 8b/10b/12b ARM32 implementation for emu_edge in 8b Improvements on the dav1dplay utility player to support 10 bit, non-4:2:0 pixel formats and film grain on the GPU https://code.videolan.org/videolan/dav1 ... aster/NEWS Jean-Baptiste Kempf: dav1d 0.7.0: mobile focus Redigerad Maj 22, 2020 av JoWa Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 22, 2020 Författare Dela Postad Maj 22, 2020 On 2020-05-19 at 20:12, JoWa sade: I dag, på WebMs tioårsdag, släpptes libaom v2.0.0 Applejack, en större uppdatering av AV1-referensimplementeringen LibAOM.https://aomedia.googlesource.com/aom/+/refs/tags/v2.0.0 Mer om förbättringarna i 2.0.0: https://groups.google.com/a/webmproject.org/forum/#!msg/codec-devel/NOTn-LlKYzw/wqCf0oKnBwAJ Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 22, 2020 Författare Dela Postad Maj 22, 2020 AV1 Turns 2.0 (Streaming Learning Center) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 23, 2020 Författare Dela Postad Maj 23, 2020 Dav1d 0.7 Speedups Are Looking Great On Various Intel + AMD CPUs (Phoronix) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 27, 2020 Författare Dela Postad Maj 27, 2020 Chromium Blog: Celebrating 10 years of WebM and WebRTC Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Juli 31, 2020 Författare Dela Postad Juli 31, 2020 libvpx v1.9.0 Quacking Duck Released What’s new: This release adds support for NV12, a separate library for rate control, as well as incremental improvements. Upgrading: NV12 support is added to this release. A new interface is added for VP9 rate control. The new library libvp9rc.a must be linked by applications. Googletest is updated to v1.10.0. simple_encode.cc is compiled into a new library libsimple_encode.a with CONFIG_RATE_CTRL. Enhancement: Various changes to improve VP9 SVC, rate control, quality and speed to real time encoding. Bug fixes: Fix key frame update refresh simulcast flexible svc. Fix to disable_16x16part speed feature for real time encoding. Fix some signed integer overflows for VP9 rate control. Fix initialization of delta_q_uv. Fix condition in regulate_q for cyclic refresh. Various fixes to dynamic resizing for VP9 SVC. https://chromium.googlesource.com/webm/ ... ags/v1.9.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad September 16, 2020 Författare Dela Postad September 16, 2020 SVT-AV1 v0.8.5 [0.8.5] - 2020-09-04 Relicensing notice Change the outbound license from BSD+Patent to the AOM license / patent Encoder Added tpl support to adaptively change lambda and quantization parameters within the frame Added multi staged hme support Quality speed trade-offs tuned to VOD use cases Added first level non-optimized support for 2pass VBR and CRF Added combined cli two pass support with options for stats being written to a memory buffer and a specified file Added non square partitioning optimizations Improved lambda generation Build and Testing Bug fixes Improve CI Improve Unit Test Coverage Address C vs asm mismatches Fix static analysis warnings / errors Add address sanitizer Fix symbol conflicts with libaom and libvpx when staticly lined to ffmpeg https://github.com/OpenVisualCloud/SVT- ... tag/v0.8.5 Rav1e 0.4.0-alpha This is a new big release of rav1e after 7 months making the encoder sensibly faster and better. https://github.com/xiph/rav1e/releases/tag/v0.4.0-alpha Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Oktober 10, 2020 Författare Dela Postad Oktober 10, 2020 AV1 Hardware Accelerated Video on Windows 10 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad November 28, 2020 Författare Dela Postad November 28, 2020 Dav1d 0.8.0 “Eurasian hobby”: 0.8.0 is a major update for dav1d: Improve the performance by using a picture buffer pool; The improvements can reach 10% on some cases on Windows. Support for Apple ARM Silicon ARM32 optimizations for 8bit bitdepth for ipred paeth, smooth, cfl ARM32 optimizations for 10/12/16bit bitdepth for mc_avg/mask/w_avg, put/prep 8tap/bilin, wiener and CDEF filters ARM64 optimizations for cfl_ac 444 for all bitdepths x86 optimizations for MC 8-tap, mc_scaled in AVX2 x86 optimizations for CDEF in SSE and {put/prep}_{8tap/bilin} in SSSE3 https://code.videolan.org/videolan/dav1 ... aster/NEWS Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad November 29, 2020 Författare Dela Postad November 29, 2020 SVT-AV1 v0.8.6 [0.8.6] - 2020-11-28 Encoder Further quality-speed tradeoffs tuning for VOD use cases Improved TPL support within 1-pass and 2-pass CRF moode Continued non-optimized support for 2pass VBR and CRF Align kernel nomenclature to prefix svt_aom for kernels brough from libaom to avoid symbol conflicts Build and Testing Bug fixes Improve CI Added CI support for gitlab Improve Unit Test Coverage Address C vs asm mismatches Fix static analysis warnings / errors Add address sanitizer Fix symbol conflicts with libaom and libvpx when staticly linked to ffmpeg https://github.com/AOMediaCodec/SVT-AV1/releases/tag/v0.8.6 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Februari 16, 2021 Författare Dela Postad Februari 16, 2021 Rav1e 0.5.0-alpha ————————————————————————————————————————————— Dav1d 0.8.2 ‘Eurasian hobby’: 0.8.2 is a middle-size update of the 0.8.0 branch: ARM32 optimizations for ipred in 10/12bits, completing most of the 10b/12b work on ARM Give the post-filters their own threads ARM64: rewrite the wiener functions Speed up coefficient decoding, 0.5%–3% global decoding gain x86: rewrite the SGR AVX2 asm x86: improve msac speed on SSE2+ machines ARM32: improve speed of ipred and warp ARM64: improve speed of ipred, cdef_dir, cdef_filter, warp_motion and itx16 ARM32/64: improve speed of looprestoration Add seeking, pausing to the player Update the player for rendering of 10b/12b Misc speed improvements and fixes on all platforms Add a xxh3 muxer in the dav1d application https://code.videolan.org/videolan/dav1 ... aster/NEWS Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Mars 24, 2021 Författare Dela Postad Mars 24, 2021 libaom v3.0.0 Braeburn Finalized https://aomedia.googlesource.com/aom/+/v3.0.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Mars 25, 2021 Författare Dela Postad Mars 25, 2021 libvpx v1.10.0 Ruddy Duck Finalized https://chromium.googlesource.com/webm/libvpx/+/refs/tags/v1.10.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 4, 2021 Författare Dela Postad Maj 4, 2021 libaom v3.1.0 Celestia Released https://aomedia.googlesource.com/aom/+/refs/tags/v3.1.0 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 9, 2021 Författare Dela Postad Maj 9, 2021 SVT-AV1 0.8.7 (2021-05-08) Encoder Feature optimizations: creating new mode decision / encode-decode feature levels allowing better speed / quality trade-off granularity Preset repositioning after adopting new levels Preset 8 achieving similar speed levels to that of x265 medium in the VOD (shot-based encoding) use-case while maintaining quality gains New 1-pass and 2-pass VBR implementation ported from libaom and adapted to the SVT architecture – still a WIP Cleaned up old VBR and CVBR RC code along with the lookahead mechanism associated with them Improvements for TPL algorithm to handle long clips and easy content Added HDR support and color primaries SEI signaling (off by default until integrated with ffmpeg) Memory optimizations, cleaning up data structures to reduce memory usage up to 2× memory reduction in multi-threaded VBR environment Additional AVX2 and AVX512 optimizations Cleaned up unused command line parameters except the config params that are linked to ffmpeg Update user guide and documentation https://gitlab.com/AOMediaCodec/SVT-AV1/-/releases/v0.8.7 Libaom, SVT-AV1 Mark New Open-Source AV1 Encoder Releases This Week (Phoronix) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Maj 16, 2021 Författare Dela Postad Maj 16, 2021 Dav1d 0.9.0 ‘Golden Eagle’: 0.9.0 is a major version of dav1d, adding notably 10b acceleration on x64. Details: x86 (64bit) AVX2 implementation of most 10b/12b functions, which should provide a large boost for high-bitdepth decoding on modern x86 computers and servers. ARM64 neon implementation of FilmGrain (4:2:0/4:2:2/4:4:4 8bit) New API to signal events happening during the decoding process https://code.videolan.org/videolan/dav1 ... aster/NEWS Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Juni 9, 2021 Författare Dela Postad Juni 9, 2021 libaom v3.1.1 Released https://aomedia.googlesource.com/aom/+/refs/tags/v3.1.1 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Juli 20, 2021 Författare Dela Postad Juli 20, 2021 Dav1d 0.9.1 ‘Golden Eagle’: 0.9.1 is a middle-size revision of dav1d, adding notably 10b acceleration for SSSE3: 10/12b SSSE3 optimizations for mc (avg, w_avg, mask, w_mask, emu_edge), prep/put_bilin, prep/put_8tap, ipred (dc/h/v, paeth, smooth, pal, filter), wiener, sgr (10b), warp8x8, deblock, film_grain, cfl_ac/pred for 32bit and 64bit x86 processors Film grain NEON for fguv 10/12b, fgy/fguv 8b and fgy/fguv 10/12 arm32 Fixes for filmgrain on ARM itx 4x4 for SSE4 Misc improvements on SSE2, SSE4 https://code.videolan.org/videolan/dav1d/-/blob/master/NEWS Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Juli 23, 2021 Författare Dela Postad Juli 23, 2021 libaom v3.1.2 Released https://aomedia.googlesource.com/aom/+/refs/tags/v3.1.2 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Augusti 9, 2021 Författare Dela Postad Augusti 9, 2021 Rav1e 0.5.0 beta Rav1e 0.5 Beta Released For This Rust-Written AV1 Encoder (Phoronix) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad September 5, 2021 Författare Dela Postad September 5, 2021 Dav1d 0.9.2 ‘Golden Eagle’: 0.9.2 is a small update of dav1d on the 0.9.x branch: x86: SSE4 optimizations of inverse transforms for 10bit for all sizes x86: mc.resize optimizations with AVX2/SSSE3 for 10/12b x86: SSSE3 optimizations for cdef_filter in 10/12b and mc_w_mask_422/444 in 8b ARM NEON optimizations for FilmGrain Gen_grain functions Optimizations for splat_mv in SSE2/AVX2 and NEON x86: SGR improvements for SSSE3 CPUs x86: AVX2 optimizations for cfl_ac https://code.videolan.org/videolan/dav1d/-/blob/master/NEWS Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
