Firefox 52.0: https://www.mozilla.org/en-US/firefox/all/
  • new
    • Added support for WebAssembly, an emerging standard that brings near-native performance to Web-based games, apps, and software libraries without the use of plugins.
    • Implemented the Strict Secure Cookies specification which forbids insecure HTTP sites from setting cookies with the “secure” attribute. In some cases, this will prevent an insecure site from setting a cookie with the same name as an existing “secure” cookie from the same base domain.
    • Added user warnings for non-secure HTTP pages with logins. Firefox now displays a “This connection is not secure” message when users click into the username and password fields on pages that don’t use HTTPS.
    • Enabled multi-process Firefox for Windows users with touch screens
    • Enhanced Sync to allow users to send and open tabs from one device to another.
  • fixed
    • Various security fixes
    • Improved text input for third-party keyboard layouts on Windows. This will address some keyboard layouts that
      • have chained dead keys
      • input two or more characters with a non-printable key or a dead key sequence
      • input a character even when a dead key sequence failed to compose a character
  • changed
    • Removed support for Netscape Plugin API (NPAPI) plugins other than Flash. Silverlight, Java, Acrobat and the like are no longer supported.
    • Display (but allow users to override) an “Untrusted Connection” error when encountering SHA-1 certificates that chain up to a root certificate included in Mozilla’s CA Certificate Program. (Note: Firefox continues to permit SHA-1 certificates that chain to manually imported root certificates.) Read more about the Mozilla Security Team’s plans to deprecate SHA-1
    • Improved experience for downloads:
    • Notification in the toolbar when a download fails
    • Quick access to five most recent downloads rather than three
    • Larger buttons for canceling and restarting downloads
    • Removed Battery Status API to reduce fingerprinting of users by trackers
    • When not using Direct2D on Windows, Skia is used for content rendering
    • Migrated Firefox users on Windows XP and Windows Vista operating systems to the extended support release (ESR) version of Firefox.
  • developer
  • unresolved
https://www.mozilla.org/en-US/firefox/52.0/releasenotes/
Dela detta inlägg
Länk till inlägg
Firefox 53.0: https://www.mozilla.org/sv-SE/firefox/new/
  • new
    • Improved graphics stability for Windows users with the addition of compositor process separation (Quantum Compositor)
    • Two new ‘compact’ themes available in Firefox, dark and light, based on the Firefox Developer Edition theme
    • Lightweight themes are now applied in private browsing windows
    • Reader Mode now displays estimated reading time for the page
    • Windows 7+ users on 64-bit OS can select 32-bit or 64-bit versions in the stub installer
  • fixed
  • changed
    • Updated the design of site permission requests to make them harder to miss and easier to understand
    • Windows XP and Vista are no longer supported. XP and Vista users running Firefox 52 will continue to receive security updates on Firefox ESR 52.
    • 32-bit Mac OS X is no longer supported. 32-bit Mac OS X users can switch to Firefox ESR 52 to continue receiving security updates.
    • Updates for Mac OS X are smaller in size compared to updates for Firefox 52
    • New visual design for audio and video controls
    • Ended Firefox Linux support for processors older than Pentium 4 and AMD Opteron
    • The last few characters of shortened tab titles fade out instead of being replaced by ellipses to keep more of the title visible
  • developer
    • Changes for web developers
    • Support for WebM video with alpha, which allows playing videos with transparent backgrounds
https://www.mozilla.org/en-US/firefox/53.0/releasenotes/
Dela detta inlägg
Länk till inlägg
Firefox 53.0.3: https://www.mozilla.org/sv-SE/firefox/new/
  • fixed
    • Fix excessive resource usage from the captive portal detection service (bug 1359697)
    • FIx hangs when using a proxy with NTLM authentication (bug 1360574)
  • changed
    • Bump preloaded security information expiration times (bug 1364240)
https://www.mozilla.org/en-US/firefox/53.0.3/releasenotes/
Dela detta inlägg
Länk till inlägg
Firefox 54.0: https://www.mozilla.org/sv-SE/firefox/new/
  • new
    • Added Burmese (my) locale
    • Added support for multiple content processes (e10s-multi)
    • Simplified the download button and download status panel
  • fixed
  • changed
    • Moved the mobile bookmarks folder to the main bookmarks menu for easier access
  • developer
https://www.mozilla.org/en-US/firefox/54.0/releasenotes/
The Mozilla Blog: The Best Firefox Ever
Redigerad av JoWa
Dela detta inlägg
Länk till inlägg
Det märks att Firefox blir bättre och bättre och att funkar bäst i 64-bitar och att den är lite snabbare
Dela detta inlägg
Länk till inlägg
Firefox 54.0.1: https://www.mozilla.org/sv-SE/firefox/new/
https://www.mozilla.org/en-US/firefox/54.0.1/releasenotes/
Utifrån det som skrevs om Firefox 54 och dess multiprocessläge, blev jag förvånad då jag installerade Firefox på Windows 10 och upptäckte att multiprocessläget alltjämt är avstängt som förval.
För att slå på det, får man gå till about:config och ändra browser.tabs.remote.autostart till true. Efter det beter sig Firefox som IE7 (Skyddat läge) på Vista: allt webbinnehåll (alla flikar) körs i en innehållsprocess med låg integritetsnivå. Vill man köra varje flik i en egen process, får man öka antalet processer i dom.ipc.processCount till ett högre tal än ett, kanske tio eller tjugo.
Sandlådan i Firefox är inte färdigutvecklad än (befinner sig på Level 1), men redan att köra innehållsprocesserna på låg integritetsnivå och starkare skydd mot buffertöverskridning (se Mitigations) är värdefullt.
Vissa tillägg hindrar multiprocessläget. Det kan man se på about:support.
Dela detta inlägg
Länk till inlägg
Efter uppgradering av Firefox 56.0.2 till 57.0 då känner man inte igen utseendet nytt gränssnitt bl.a. nya flikar liknar Opera och Google Chrome. Och så nya namnet Firefox Quantum. Äntligen något nytt i Firefox bra med snabbåtkomst med Mest Besökta alltid kul med något nytt. Fliksystemet den hade förut har hängt med länge
Dela detta inlägg
Länk till inlägg
Märker att Firefox 57.0 är väldigt stabil jämfört med dem föregående versionerna och att än så länge inte har släppts säkerhets uppdateringar som det alltid kom efter en release.
Dela detta inlägg
Länk till inlägg
On 2017-11-25 at 22:05, DAson sade:
Citat
Crash on Broadwell-U with old microcode
On Windows and Linux, Firefox 57 and later crashes occasionally on Intel Broadwell-U processors unless the processor has sufficiently recent microcode.
The crash occurs if the processor vendor is GenuineIntel, family is 6, model is 61, stepping is 4 and microcode revision is 19 (hexadecimal) or lower.
Broadwell-U processors are typically used in laptops released in 2015.
https://support.mozilla.org/en-US/kb/broadwell-u-microcode
Dela detta inlägg
Länk till inlägg
Laddar...
  • Liknande innehåll
    • Av JoWa
      Mozilla Thunderbird
      Portabel version (PortableApps.com)
    • Av JoWa
      I dag släpptes Vivaldi 1.0, den första stabila versionen av en ny webbläsare. Vivaldi utvecklas till stor del av tidigare Opera-utvecklare, som ett alternativ till ”nya” Opera, som många användare sedan Presto-tiden (Opera före Chromium) inte är nöjda med.
      Vivaldi 1.0: Not for everybody, just you
      Vivaldi för Windows finns som 32-bit och 64-bit, den senare ”experimentell”: https://vivaldi.com/download/
      Bakgrund: https://vivaldi.com/story/
      Version 1.0.435.38 är baserad på Chromium 49.0.2623.110 (samma version som Chrome stabil, f.n.).
    • Av melo
      Hej!
      Hur gör man att få rättstavning på svenska till min Firefox?
    • Av JoWa
      Secure Sockets Layer (SSL) utvecklades av Netscape, och lanserades (version 2.0) i februari 1995. SSL uppdaterades till version 3.0 1996. SSL är ett kryptografiskt protokoll som används för att skapa säkra (krypterade) förbindelser över Internet.
      Utvecklingen gick vidare, och SSL fick en efterträdare i Transport Layer Security (TLS). Version 1.0 av TLS lanserades i januari 1999, följd av TLS 1.1 (april 2006) och TLS 1.2 (april 2008).
      Alla dessa versioner kan ännu användas, men SSL 2.0 är en mycket osäker version, och väldigt får servrar stöder SSL 2.0. I ingen av dagens webbläsare är SSL 2.0 aktiverat, och endast Internet Explorer (t.o.m. version 10) har möjlighet att aktivera den osäkra protokollversionen.
      TLS 1.0 är den mest använda protokollversionen. Alla (?) servrar stöder den, och alla webbläsare har sedan länge stöd för TLS 1.0 aktiverat som standard.
      Internet Explorer i Windows 7 och 8 stöder även TLS 1.1 och 1.2, men dessa versioner är inte aktiverade som standard. För att aktivera, öppna Internetalternativ, fliken Avancerat, rubriken Säkerhet. Markera ”Använd TLS 1.1” och ”Använd TLS 1.2”. Markera inte ”Använd SSL 2.0”.
      Opera stöder även TLS 1. 1 och 1.2, men det är inte heller där aktiverat som standard. För att aktivera, gå till Inställningar, Avancerat, Säkerhet, Säkerhetsprotokoll.
      Eller skriv opera:config i adressfältet, tryck Retur. Skriv ”tls” i sökrutan och markera ”Enable TLS v1.1” och ”Enable TLS v1.2”.
      Firefox och Chrome använder Network Security Services (NSS), som stöder upp till TLS 1.1. I Chrome är TLS 1.1 aktiverat som standard, medan Firefox ännu (v. 18) endast stöder SSL 3.0 och TLS 1.0.
      I Opera och Chrome kan man lätt se vilket krypteringsprotokoll som används, se bifogade bilder.
      Läsning:
      Wikipedia: Transport Layer Security
      Wikipedia: Network Security Services
      Adam Langley (Google): New TLS versions
    • Av Hampus
      Hej!
      Kan jag inaktivera Microsoft Edge, den startar upp om jag ex.vis klickar på länkar i ett mail, men för min del så föredrar jag Chrome
      före både Edge och IE.  Finns ju ett val där jag markerat och valt Chrome men det verkar inte fungera.
      Mvh
      Hampus
      EDIT: "Grävde" lite på näten och hittade en lösning.
      https://www.youtube.com/watch?v=vfCBRKoce3o
    • Av JoWa
      Som Microsoft meddelade tidigare¹, uppdateras ej längre äldre versioner av Internet Explorer. Med äldre menas alla versioner utom den senaste för varje Windows-version.
      De versioner som stöds²:
      Windows Vista SP2: Internet Explorer 9 Windows 7 SP1: Internet Explorer 11 Windows 8.1 Update: Internet Explorer 11 Windows 10: Internet Explorer 11 Versioner som inte längre uppdateras är IE7, IE8 i Windows Vista och IE8, IE9, IE10 i Windows 7. Windows 8 får inte längre några uppdateringar alls.
      ¹ https://www.microsoft.com/en-us/WindowsForBusiness/End-of-IE-support
      ² https://support.microsoft.com/en-us/lifecycle#gp/Microsoft-Internet-Explorer
