  • 2 weeks later...
  • Svar 472
  • Created
  • Senaste svar
Top Posters In This Topic
Popular Posts
Tråkigt att Pale Moon är baserad på Firefox ESR (nu 24.5.0). Nästa större uppdatering sker när Firefox ESR 31 släpps.
Firefox 34.0.5 finns inte har bara Firefox 34.0 och inte 34.0.5.
Har märkt att 64-bitars versionen av Firefox är stabilare än 32-bitars versionen och snabbare Firefox blir bättre och bättre.
Posted Images
Postad (redigerade)
Firefox 30.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/30.0/win32/sv-SE/
  • NEW Sidebars button in browser chrome enables faster access to social, bookmark, & history sidebars
  • NEW Mac OS X command-E sets find term to selected text
  • NEW Support for GStreamer 1.0
  • CHANGED Disallow calling WebIDL constructors as functions on the web
  • DEVELOPER With the exception of those bundled inside an extension or ones that are whitelisted, plugins will no longer be activated by default (see blog post)
  • DEVELOPER Fixes to box-shadow and other visual overflow (see bug 480888)
  • DEVELOPER Mute and volume available per window when using WebAudio
  • DEVELOPER background-blend-mode enabled by default
  • DEVELOPER Use of line-height allowed for <input type=“reset|button|submit”>
  • DEVELOPER ES6 array and generator comprehensions implemented (read docs for more details)
  • DEVELOPER Error stack now contains column number
  • DEVELOPER Support for alpha option in canvas context options (feature description)
  • FIXED Ignore autocomplete=“off” when offering to save passwords via the password manager (see 956906)
  • FIXED TypedArrays don’t support new named properties (see 695438)
https://www.mozilla.org/en-US/firefox/30.0/releasenotes/
Redigerad av JoWa
Länk till inlägg
Firefox 31 beta: https://www.mozilla.org/sv-SE/firefox/channel/#beta
  • NEW Add the search field to the new tab page
  • NEW Integration of generational garbage collection
  • NEW OdinMonkey: Use backtracking allocator for asm.js style code
  • NEW mozilla::pkix as default certificate verifier
  • NEW audio/video .ogg and .pdf files handled by Firefox if no application specified (Windows only)
  • NEW Partial implementation of the OpenType MATH table (section 6.3.6) see documentation about mathematical fonts and the MathML Torture Test for details
  • CHANGED Removal of the CAPS infrastructure for specifying site-specific permissions (via capability.policy.* preferences). Most notably, attempts to use this functionality to grant access to the clipboard will no longer work. The sole exception is the checkloaduri permission, which may still be used as before to allow sites to load file:// URIs.
  • HTML5 WebVTT implemented and enabled (learn more)
  • HTML5 CSS3 variables implemented
  • DEVELOPER navigator.sendBeacon enabled by default
  • DEVELOPER New Array built-in: Array.prototype.fill() (learn more)
  • DEVELOPER New Object built-in: Object.setPrototypeOf() (learn more)
  • DEVELOPER CSP 1.1 nonce-source and hash-source enabled by default
  • DEVELOPER Dialogs spawned from the onbeforeunload event no longer block access to the rest of the browser
  • DEVELOPER Developer Tools: Eyedropper tool added to the color picker (learn more)
  • DEVELOPER Developer Tools: Editable Box Model (learn more)
  • DEVELOPER Developer Tools: Code Editor improvements (learn more)
  • DEVELOPER Developer Tools: Console stack traces (learn more)
  • DEVELOPER Developer Tools: Copy as cURL (learn more)
  • DEVELOPER Developer Tools: Styled console logs (learn more)
  • DEVELOPER Developer Tools: Add-on Debugger (learn more)
  • DEVELOPER Developer Tools: Canvas Debugger (learn more)
  • FIXED Search for partially selected link text from context menu (985824)
Länk till inlägg
  • 1 month later...
Postad (redigerade)
Firefox 31.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/31.0/win32/sv-SE/
  • NEW Support of Prefer:Safe http header for parental control (learn more)
  • NEW mozilla::pkix as default certificate verifier (learn more)
  • NEW Block malware from downloaded files (learn more)
  • NEW Upper Sorbian [hsb] locale added
  • HTML5 CSS3 variables implemented (learn more)
  • DEVELOPER navigator.sendBeacon enabled by default (learn more)
  • FIXED Various security fixes
Redigerad av JoWa
Länk till inlägg
Firefox 32 betahttps://www.mozilla.org/sv-SE/firefox/channel/#beta
  • NEW New HTTP caching (v2) enabled by default (learn more)
  • NEW Public key pinning support enabled (learn more)
  • NEW Login metadata viewable in password manager
  • NEW Display the number of found items in the find toolbar
  • NEW Code completion and inline documentation added to Scratchpad (learn more)
  • NEW Connect to HTTP proxy over HTTPS
  • CHANGED Performance improvements to Password Manager and Add-on Manager
  • CHANGED Removed and turned off trust bit for some 1024-bit root certificates
  • HTML5 Vibration API updated to latest W3C spec
  • HTML5 CSS box-decoration-break replaces -moz-background-inline-policy (learn more)
  • HTML5 ECMAScript 6 built-in method Array#copyWithin implemented (docs)
  • HTML5 CSS position:sticky enabled by default
  • HTML5 drawFocusIfNeeded enabled by default
  • HTML5 mix-blend-mode enabled by default
  • HTML5 New Array built-in: Array.from() (learn more)
  • HTML5 navigator.languages property and languagechange event implemented (learn more)
  • DEVELOPER HiDPI support in Developer Tools UI
  • DEVELOPER Inspector button moved to the top left
  • DEVELOPER New Web Audio Editor (learn more)
  • DEVELOPER Hidden nodes displayed differently in the markup-view
  • FIXED Mac OS X: cmd-L does not open a new window when no window is available
  • FIXED Text Rendering Issues on Windows 7 with Platform Update KB2670838 (MSIE 10 Prerequisite) or on Windows 8.1
Länk till inlägg
  • 1 month later...
Firefox 32.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/32.0/win32/sv-SE/
https://www.mozilla.org/en-US/firefox/32.0/releasenotes/
Redigerad av JoWa
Länk till inlägg
Firefox 33 betahttps://www.mozilla.org/sv-SE/firefox/channel/#beta
  • NEW Enhanced Tiles
  • NEW Continued experimentation with WebRTC-powered communications feature
  • NEW OpenH264 support (sandboxed)
  • NEW Slimmer and faster JavaScript strings (learn more)
  • NEW Improved reliability of the session restoration (learn more)
  • NEW New CSP (Content Security Policy) backend
  • NEW Improved search experience through the location bar
  • NEW Search suggestions on the Firefox Start Page (about:home)
  • NEW Azerbaijani [az] locale added
  • CHANGED JSD (JavaScript Debugger Service) removed in favor of the Debugger interface (learn more)
  • CHANGED Proprietary window.crypto properties/functions removed
  • HTML5 DOMMatrix interface implemented
  • HTML5 @counter-style rule from CSS3 Counter Styles specification implemented
  • HTML5 WebCrypto: wrapKey and unwrapKey implemented
  • HTML5 WebCrypto: Import/export of JWK-formatted keys
  • HTML5 WebCrypto: RSA-OAEP, PBKDF2 and AES-KW support
  • DEVELOPER Developer tools: Paint flashing for browser content repaints
  • DEVELOPER Cubic-bezier curves editor
  • DEVELOPER Display which elements have listeners attached
  • DEVELOPER New sidebar which displays a list of shortcuts to every @media rule in the current stylesheet
  • DEVELOPER Editable @keyframes rules in the Rules section of the Inspector
  • DEVELOPER CSS transform highlighter to the style-inspector
”OpenH264 support” innebär att Firefox 33 använder Ciscos AVC-kodare (en sluten plugg). Mer om detta i Video Interoperability on the Web Gets a Boost From Cisco’s H.264 Codec
Future Releases:
Redigerad av JoWa
Länk till inlägg
32.0.1: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/32.0.1/win32/sv-SE/
  • FIXED 32.0.1 - Start-up crash when using switchable Intel+ATI graphics cards
  • FIXED 32.0.1 - Mixed content icon may be incorrectly displayed instead of lock icon for SSL sites
  • FIXED 32.0.1 - WebRTC: setRemoteDescription() silently fails if no success callback is specified
Länk till inlägg
  • 3 weeks later...
33.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/33.0/win32/sv-SE/
https://www.mozilla.org/en-US/firefox/33.0/releasenotes/
Redigerad av JoWa
Länk till inlägg
Firefox 34 betahttps://www.mozilla.org/sv-SE/firefox/channel/#beta
  • NEW Firefox Hello real-time communication client
  • NEW Easily switch themes/personas directly in the Customizing mode
  • NEW Built-in support for H264 (MP4) on Mac OS X Leopard (10.6) and newer through native APIs
  • NEW Wikipedia search now uses HTTPS for secure searching
  • NEW Non-intrusive way to set Firefox as default browser
  • NEW Implementation of HTTP/2 (draft14) and ALPN
  • NEW Recover from a locked Firefox process in the "Firefox is already running" dialog on Windows
  • HTML5 ECMAScript 6 WeakSet Implemented
  • HTML5 JavaScript Template Strings Implemented
  • HTML5 CSS3 Font variants and features control (e.g. kerning) implemented
  • HTML5 matches() DOM API implemented (formerly mozMatchesSelector())
  • HTML5 Performance.now() for workers implemented
  • HTML5 WebCrypto: ECDH support
  • HTML5 Support for the ECMAScript 6 Symbol data type added
  • DEVELOPER WebIDE: Create, edit, and test a new Web application from your browser
  • DEVELOPER Highlight all nodes that match a given selector in the Style Editor and the Inspector's Rules panel
  • DEVELOPER Improved User Interface of the Profiler
  • DEVELOPER console.table function added to web console
  • FIXED CSS transitions start correctly when started at the same time as changes to display, position, overflow, and similar properties
I beta 1 är SSL3 ännu inte inaktiverat, vilket tidigare har sagts vara på gång för Firefox 34. Uppdatering: SSL3 är inaktiverat i beta 3.
Redigerad av JoWa
Länk till inlägg
  • 2 weeks later...
I går fyllde Firefox 10 år. :) Den 9 november 2004 släpptes Firefox 1.0.
2004… Nästan alla använde IE6, som då var tre år gammal, och skulle bli ytterligare två år innan IE7 (med flikar, som Firefox!) lanserades. Webben var långsam på den tiden, men Firefox gjorde den snabbare och bättre.
Celebrating 10 Years of Firefox
mozilla.org 2004-11-09 (web.archive.org)
Historien bakom projektet Mozilla
Mozilla Foundation releases the highly anticipated Mozilla Firefox 1.0 web browser
History of Firefox (Wikipedia)
Redigerad av JoWa
Länk till inlägg
  • JoWa changed the title to Firefox 88.0
Laddar...
  • Liknande innehåll
    • Av JoWa
      https://www.opera.com/
    • Av JoWa
      Mozilla Thunderbird
      Portabel version (PortableApps.com)
    • Av JoWa
      I dag släpptes Vivaldi 1.0, den första stabila versionen av en ny webbläsare. Vivaldi utvecklas till stor del av tidigare Opera-utvecklare, som ett alternativ till ”nya” Opera, som många användare sedan Presto-tiden (Opera före Chromium) inte är nöjda med.
      Vivaldi 1.0: Not for everybody, just you
      Vivaldi för Windows finns som 32-bit och 64-bit, den senare ”experimentell”: https://vivaldi.com/download/
      Bakgrund: https://vivaldi.com/story/
      Version 1.0.435.38 är baserad på Chromium 49.0.2623.110 (samma version som Chrome stabil, f.n.).
    • Av melo
      Hej!
      Hur gör man att få rättstavning på svenska till min Firefox?
    • Av JoWa
      Secure Sockets Layer (SSL) utvecklades av Netscape, och lanserades (version 2.0) i februari 1995. SSL uppdaterades till version 3.0 1996. SSL är ett kryptografiskt protokoll som används för att skapa säkra (krypterade) förbindelser över Internet.
      Utvecklingen gick vidare, och SSL fick en efterträdare i Transport Layer Security (TLS). Version 1.0 av TLS lanserades i januari 1999, följd av TLS 1.1 (april 2006) och TLS 1.2 (april 2008).
      Alla dessa versioner kan ännu användas, men SSL 2.0 är en mycket osäker version, och väldigt får servrar stöder SSL 2.0. I ingen av dagens webbläsare är SSL 2.0 aktiverat, och endast Internet Explorer (t.o.m. version 10) har möjlighet att aktivera den osäkra protokollversionen.
      TLS 1.0 är den mest använda protokollversionen. Alla (?) servrar stöder den, och alla webbläsare har sedan länge stöd för TLS 1.0 aktiverat som standard.
      Internet Explorer i Windows 7 och 8 stöder även TLS 1.1 och 1.2, men dessa versioner är inte aktiverade som standard. För att aktivera, öppna Internetalternativ, fliken Avancerat, rubriken Säkerhet. Markera ”Använd TLS 1.1” och ”Använd TLS 1.2”. Markera inte ”Använd SSL 2.0”.
      Opera stöder även TLS 1. 1 och 1.2, men det är inte heller där aktiverat som standard. För att aktivera, gå till Inställningar, Avancerat, Säkerhet, Säkerhetsprotokoll.
      Eller skriv opera:config i adressfältet, tryck Retur. Skriv ”tls” i sökrutan och markera ”Enable TLS v1.1” och ”Enable TLS v1.2”.
      Firefox och Chrome använder Network Security Services (NSS), som stöder upp till TLS 1.1. I Chrome är TLS 1.1 aktiverat som standard, medan Firefox ännu (v. 18) endast stöder SSL 3.0 och TLS 1.0.
      I Opera och Chrome kan man lätt se vilket krypteringsprotokoll som används, se bifogade bilder.
      Läsning:
      Wikipedia: Transport Layer Security
      Wikipedia: Network Security Services
      Adam Langley (Google): New TLS versions
    • Av Hampus
      Hej!
      Kan jag inaktivera Microsoft Edge, den startar upp om jag ex.vis klickar på länkar i ett mail, men för min del så föredrar jag Chrome
      före både Edge och IE.  Finns ju ett val där jag markerat och valt Chrome men det verkar inte fungera.
      Mvh
      Hampus
      EDIT: "Grävde" lite på näten och hittade en lösning.
      https://www.youtube.com/watch?v=vfCBRKoce3o
