GÄ till innehÄll
🩊 Firefox 125.0.2
JoWa
  • 1 mĂ„nad senare...
21.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/21.0/win32/sv-SE/
  • NEW Enhanced three-state UI for Do Not Track (DNT)
  • NEW Firefox will suggest how to improve your application startup time if needed
  • NEW Preliminary implementation of Firefox Health Report (see FAQ)
  • CHANGED Ability to Restore removed thumbnails on New tab Page
  • CHANGED Add-ons History API removals in Places
  • CHANGED CSS -moz-user-select:none selection changed to improve compatibility with -webkit-user-select:none (bugs 816298)
  • CHANGED Graphics related performance improvements (bugs 809821)
  • CHANGED Removed E4X support from SpiderMonkey
  • DEVELOPER Implemented Remote Profiling
  • DEVELOPER Integrated, Add-on SDK loader and API libraries into Firefox
  • HTML5 Added support for <main> element
  • HTML5 Implemented scoped stylesheets
  • FIXED Some function keys may not work when pressed (833719)
  • FIXED Browsing and Download history clearing needs unification to avoid confusion on clearing download history (847627)
LĂ€nk till kommentar
Dela pÄ andra webbplatser
22.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/22.0/win32/sv-SE/
  • NEW Windows: Firefox now follows display scaling options to render text larger on high-res displays
  • NEW WebRTC is now enabled by default!
  • NEW Mac OS X: Download progress in Dock application icon
  • NEW HTML5 audio/video playback rate can now be changed
  • NEW Social services management implemented in Add-ons Manager
  • NEW asm.js optimizations (OdinMonkey) enabled for major performance improvements
  • CHANGED Improved WebGL rendering performance through asynchronous canvas updates
  • CHANGED Plain text files displayed within Firefox will now word-wrap
  • CHANGED For user security, the |Components| object is no longer accessible from web content
  • CHANGED Improved memory usage and display time when rendering images
  • CHANGED Pointer Lock API can now be used outside of fullscreen
  • DEVELOPER CSS3 Flexbox implemented and enabled by default
  • DEVELOPER New Web Notifications API implemented
  • DEVELOPER Added clipboardData API for JavaScript access to a user's clipboard
  • DEVELOPER New built-in font inspector
  • HTML5 New HTML5 <data> and <time> elements
  • FIXED Scrolling using some high-resolution-scroll aware touchpads feels slow (829952)
Ja, det Àr vÀl en del av
  • CHANGED "Load images automatically", "Enable JavaScript", and Always show the tab bar" checkboxes removed from preferences
Kanske kan anpassas i about:config. Aktivering/inaktivering av SSL- och TLS-versioner har flyttats frÄn InstÀllningar till about:config.
FÄr intrycket av att frÄn ver 23.1 Àr flikar obligatoriskt. Hittar ingenstans att stÀnga av dem.
Menar du att flikraden numera alltid visas Àven nÀr man bara har en flik öppen? Vilket man tidigare kunde vÀlja om man ville ha det sÄ eller inte. Eller menar du nÄgot helt annat? För man har vÀl inte helt kunnat stÀnga av flikar de senaste Ären, Àven om man i praktiken kunnat fÄ det att se ut som att man inte anvÀnde dem.
Precis. Nu visas alltid minst en flik i den övre delen av programfönstret.
Firefox 23.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/23.0/win32/sv-SE/
  • NEW Support for new scrollbar style in Mac OS X 10.7 and newer
  • NEW Mixed content blocking enabled to protects users from man-in-the-middle attacks and eavesdroppers on HTTPS pages (learn more)
  • CHANGED Improved about:memory's functional UI
  • CHANGED Enabled DXVA2 on Windows Vista+ to accelerate H.264 video decoding
  • CHANGED Updated Firefox Logo
  • CHANGED Simplified interface for notifications of plugin installation
  • CHANGED Users can now switch to a new search provider across the entire browser
  • CHANGED CSP policies using the standard syntax and semantics will now be enforced
  • DEVELOPER Implemented a global browser console
  • DEVELOPER Social share functionality
  • DEVELOPER HTML5 <input type="range"> form control implemented
  • DEVELOPER Write more accessible pages on touch interfaces with new ARIA role for key buttons
  • DEVELOPER Added unprefixed requestAnimationFrame
  • DEVELOPER New feature in toolbox: Nework Monitor
  • DEVELOPER Dropped blink effect from text-decoration: blink; and completely removed <blink> element
  • 2 veckor senare...
Firefox 23.0.1: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/23.0.1/win32/sv-SE/
  • FIXED 23.0.1 - Rendering glitches on H.264 video only in FF23 on Vista (901944)
  • FIXED 23.0.1 - Spellchecking broken with non-ASCII characters in profile path (902532)
  • FIXED 23.0.1 - Audio static/"burble"/breakup in Firefox to Firefox WebRTC calls (901527)
Största problemet med alla dessa uppdateringar Àr att de tillÀgg man hittat och vant sig vid plötsligt inte fungerar lÀngre.
Finns det en svensk ordlista att hÀmta till nya Firefox?
Och hur Àr det med den senaste varianten av Windows och Internet Explorer? Skulle det inte komma med en ordlista som sedan skulle kunna anvÀndas utav alla program?
Redigerad av CGD
Det kan nog stÀmma, men hoppar man pÄ nightly/beta versioner sÄ tycker jag man fÄr rÀkna med att det kan intrÀffa.
Nu har jag inte sÄ mÄnga tillÀgg men det Àr ytterst ovanligt att nÄgot av dem slutat fungera vid en officiell Firefox uppdatering.
  • 3 veckor senare...
Firefox 24.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/24.0/win32/sv-SE/
  • NEW Implemented Close tabs to the right
  • NEW Social: Ability to tear-off chat windows to view separately by simply dragging them out
  • CHANGED Accessibility related improvements on using pinned tabs (see 577727)
  • DEVELOPER Major SVG rendering improvements around Image tiling and scaling (see 600207)
  • DEVELOPER Improved and unified Browser console for enhanced debugging experience, replacing existing Error console
  • DEVELOPER Removed support for sherlock files that are loaded from application or profile directory
  • HTML5 Support for W3C touch events disabled (see 888304)
Firefox 25.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/25.0/win32/sv-SE/
  • NEW The find bar is no longer shared between tabs
  • CHANGED If away from Firefox for months, you now will be offered the option to migrate another browser's history and settings
  • CHANGED Resetting Firefox no longer clears your browsing session
  • DEVELOPER CSS3 background-attachment:local support to control background scrolling
  • DEVELOPER Many new ES6 functions implemented
  • HTML5 iframe document content can now be specified inline
Nytt i 26.0 beta:
BankID strular med SEB och den dÀr sidan som man kan test sitt BankID pÄ.
https://test.bankid.com/Desktop/Check
Fick det att funka med Handelsbanken. Kom upp nÄgon varningsruta om man ville tillÄta Nexus Personal eller inte. Klicka man OK sÄ funka det.
NĂ„gon annan som har samma strul med ver 26 b1?
Edit:
Fixade det med att Àndra till "Alltid aktiverad" pÄ Hantera tillÀgg -> Insticksmoduler.
Redigerad av Cynthia
Firefox 25.0.1: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/25.0.1/win32/sv-SE/
  • FIXED 25.0.1: New security fixes can be found here
  • FIXED 25.0.1: Pages sometimes wouldn't load without first moving the cursor
https://www.mozilla.org/en-US/firefox/25.0.1/releasenotes/
Redigerad av JoWa
Firefox 26.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/26.0/win32/sv-SE/
  • NEW All plug-ins, with the exception of recent Flash plug-ins, are defaulted to ‘click to play’
  • NEW Password manager now supports script-generated password fields
  • NEW Updates can now be performed by Windows users without write permissions to Firefox install directory (requires Mozilla Maintenance Service)
  • NEW Support for H.264 on Linux if the appropriate gstreamer plug-ins are installed
  • CHANGED Support for MP3 decoding on Windows XP, completing MP3 support across Windows OS versions
  • CHANGED CSP implementation now supports multiple policies, including the case of both an enforced and Report-Only policy, per the spec
  • DEVELOPER Social API now supports Social Bookmarking for multiple providers through its SocialMarks functionality (see MDN docs)
  • DEVELOPER There is no longer a prompt when websites use appcache
  • DEVELOPER Support for the CSS image orientation property
  • DEVELOPER New App Manager allows you to deploy and debug HTML5 webapps on Firefox OS phones and the Firefox OS Simulator
  • DEVELOPER IndexedDB can now be used as a “optimistic” storage area so it doesn’t require any prompts and data is stored in a pool with LRU eviction policy, in short temporary storage
  • FIXED When displaying a standalone image, Firefox matches the EXIF orientation information contained within the JPEG image (298619)
  • FIXED Improved page load times due to no longer decoding images that aren’t visible (847223)
  • FIXED AudioToolbox MP3 backend for OSX (914479)
https://www.mozilla.org/en-US/firefox/26.0/releasenotes/
Firefox 27.0: ftp://ftp.mozilla.org/pub/mozilla.org/firefox/releases/27.0/win32/sv-SE/
  • NEW You can now run more than one service at a time with Firefox SocialAPI, allowing you to receive notifications, chat and more from multiple integrated services
  • CHANGED Enabled TLS 1.1 (RFC 4346) and TLS 1.2 (RFC 5246) by default
  • CHANGED Added support for SPDY 3.1 protocol
  • DEVELOPER Ability to reset style sheets using 'all:unset'
  • DEVELOPER You can now choose to deobfuscate javascript in the debugger (see 762761)
  • DEVELOPER Added support for scrolled fieldsets (see 261037)
  • DEVELOPER Implemented allow-popups directive for iframe sandbox, enabling increased security (see 766282)
  • DEVELOPER CSS cursor keywords -moz-grab and -moz-grabbing have been unprefixed (see 880672)
  • DEVELOPER Added support for ES6 generators in SpiderMonkey (see blog post)
  • DEVELOPER Implemented support for mathematical function Math.hypot() in ES6 (see 896264)
  • HTML5 Dashed line support on Canvas (see 768067)
  • FIXED Get Azure/Skia content rendering working on Linux (see 740200)
  • FIXED 27.0: Security fixes can be found here
https://www.mozilla.org/en-US/firefox/27.0/releasenotes/
Redigerad av JoWa
Du kan skriva svaret nu och registrera dig senare, Om du har ett konto, logga in nu för att svara pÄ inlÀgget.
GĂ€st
Svara i detta Àmne...
×   Du har klistrat in innehĂ„ll med formatering.   Ta bort formatering
×   Din lĂ€nk har automatiskt bĂ€ddats in.   Visa som lĂ€nk istĂ€llet
