Sandstone50 Postad April 11, 2015 Författare Dela Postad April 11, 2015 Bättre ?? Fix result of Farbar Recovery Tool (FRST written by Farbar) (x64) Version: 11-03-2015Ran by Birgitta at 2015-04-11 16:14:10 Run:3Running from C:\Users\Birgitta\DesktopLoaded Profiles: Birgitta (Available profiles: Birgitta)Boot Mode: Normal============================================== Content of fixlist:*****************CreateRestorePoint:CloseProcesses:C:\Program Files (x86)\SearchProtect174081C:\Windows\System32\mjcm\BHO: Java™ Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files\Java\jre6\bin\jp2ssv.dll No FileToolbar: HKU\S-1-5-21-2449234904-2715240119-1125603432-1000 -> No Name - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - No FileFF Extension: No Name - C:\Users\Birgitta\AppData\Roaming\Mozilla\Firefox\Profiles\5x8fs8fd.default\extensions\paffxtbr@FilmFanatic.com [Not Found]FF Extension: No Name - C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd} [Not Found]2015-03-25 14:49 - 2015-03-25 14:49 - 00000000 ____D () C:\Windows\SysWOW64\Drivers\avg2015-03-25 10:28 - 2015-04-10 19:46 - 00000000 ____D () C:\ProgramData\avg9C:\Program Files (x86)\AVGC:\Windows\system32\tprbEmptyTemp:***************** Restore point was successfully created.Processes closed successfully.C:\Program Files (x86)\SearchProtect174081 => Moved successfully."C:\Windows\System32\mjcm" => File/Directory not found."HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}" => Key deleted successfully."HKCR\CLSID\{DBC80044-A445-435b-BC74-9C25C1C588A9}" => Key deleted successfully.HKU\S-1-5-21-2449234904-2715240119-1125603432-1000\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} => value deleted successfully.HKCR\CLSID\{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} => Key not found.C:\Users\Birgitta\AppData\Roaming\Mozilla\Firefox\Profiles\5x8fs8fd.default\extensions\paffxtbr@FilmFanatic.com not found.C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd} not found."C:\Windows\SysWOW64\Drivers\avg" => File/Directory not found.C:\ProgramData\avg9 => Moved successfully.C:\Program Files (x86)\AVG => Moved successfully.C:\Windows\system32\tprb => Moved successfully.EmptyTemp: => Removed 18.5 GB temporary data. The system needed a reboot. ==== End of Fixlog 16:30:40 ==== Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Sandstone50 Postad April 11, 2015 Författare Dela Postad April 11, 2015 Bordedet räcka med AVG och windows brandvägg ?? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Cecilia Postad April 11, 2015 Dela Postad April 11, 2015 Om det inte verkar finnas några annonsprogram eller skadliga program kvar i datorn är det dags att avinstallera FRST och AdwCleaner. 1. Stäng alla program, inklusive webbläsare. Dubbelklicka på AdwCleaner för att starta programmet. Klicka på Uninstall-knappen. 2. Ladda ner avinstallationsprogrammet OTC till Skrivbordet: http://oldtimer.geekstogo.com/OTC.exe Dubbelklicka på filen för att starta programmet. Tryck på knappen CleanUp! och FRST kommer att avinstalleras efter en omstart av datorn. Ta bort eventuella loggar. 3. Förbättra skyddet i datorn, se mina Råd för en säkrare dator: http://ceciliasec.wordpress.com/rad/ Det är mycket viktigt att hålla alla småprogram i datorn uppdaterade, gamla versioner av t ex Flash, Java och Adobe Reader innehåller kända säkerhetshål, vilka kan användas av en webbsida för att infektera datorn. Jag tycker att Secunias program (länk på min webbsida) är en bra hjälp för att kontrollera hur det står till med säkerhetshål i datorn och ange vad som behöver åtgärdas. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Sandstone50 Postad April 11, 2015 Författare Dela Postad April 11, 2015 Tack C !! Tror jag FIXAT DET MESTA Har du tips på snabba upp datorn, så tveka inte... tack än en gång !! Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Cecilia Postad April 11, 2015 Dela Postad April 11, 2015 Det var så lite så När är datorn långsam, start av Windows, start av program, avstängning ...? Men ominstallation av Windows och mer RAM-minne kan pigga upp en dator. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Sandstone50 Postad April 12, 2015 Författare Dela Postad April 12, 2015 Vad jag kan se så är det väl inte längre nån "spion" i datorn, men hualigen så trött och sidor låser sej och FRYSER. Inte kul att lämna iväg denna dator tillbaka senare idag. Inget mera jag kan göra ?? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Cecilia Postad April 12, 2015 Dela Postad April 12, 2015 Kan det vara så att datorn överhettar för att den är full med damm efter några år? Överhettning kan leda till långsam dator och låsningar. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Sandstone50 Postad April 12, 2015 Författare Dela Postad April 12, 2015 OK, ska tipsa om det. Dammsugning :-) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
Cecilia Postad April 12, 2015 Dela Postad April 12, 2015 Inte dammsuga inuti en dator. http://eforum.idg.se/topic/335021-ta-bort-damm-i-en-station%C3%A4r-dator/ Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
