nilsbalter Posted January 17, 2008 Share Posted January 17, 2008 Jag använder Winvista Ultimate, men jag kan inte få igång Bitlocker. Min hårddisk är partitionerad enligt följande. C: ca 40GB NTFS D: ca 10GB NTFS E: ca 130GB NTFS F: ca 130GB NTFS När jag går in i Bitlocker via kontrollpanelen står det dels att jag inte har en TPM, vilket är sant. Men det ska ju gå att använda ex. ett USB-minne till detta. Det står emellertid också att "The drive configuration is unsuitable for BitLocker Drive Encryption. To use BitLocker, please re-partition your hard drive according to the BitLocker requirements." Detta är mitt problem. Nedan har jag kopierat vad som står i Hjälpen om requirements. Before you can turn on BitLocker Drive Encryption you need t... Before you can turn on BitLocker Drive Encryption you need to make sure that your computer's hard disk has the following: At least two partitions (also called volumes). One partition is for the operating system drive (typically drive C) that BitLocker will encrypt, and one is for the active partition, which must remain unencrypted to start the computer. The size of the active partition must be at least 1.5 gigabytes (GB). To create a partition (volume) You must be logged on as an administrator to perform these steps. To create a partition (volume) on a hard disk, there must be either unallocated (empty) space on the hard disk, or free space within an extended partition on the hard disk. If there is no unallocated space, you can create some by deleting an existing volume or by using a third-party partitioning program. For more information, see Can I repartition my hard disk? On a basic disk, the first three volumes you create will be formatted as primary partitions. Beginning with the fourth volume, each volume will be configured as a logical drive within an extended partition. For more information, see What are partitions and logical drives? and What are basic and dynamic disks? Click to open Computer Management. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. In the left pane, under Storage, click Disk Management. Right-click an unallocated region on your hard disk, and then click New Simple Volume. Follow the instructions in the New Simple Volume Wizard to create a new volume. Both partitions must be formatted with the NTFS file system. To format a partition (volume) You can format an existing partition or a newly created volume. You must be logged on as an administrator to perform these steps. Warning Formatting a volume will destroy any data on the partition. If you need to save data on the volume, either temporarily or permanently move the data to another storage device or location before you proceed. Click to open Computer Management. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. In the navigation pane, under Storage, click Disk Management. Right-click the volume that you want to format, and then click Format. To format the volume with the default settings, in the Format dialog box, click OK, and then click OK again. If your computer meets these requirements, you can turn on BitLocker. Om jag kör BitLocker Drive Preparation Tool (BdeHdCfg.exe), står det inledningsvis att "D: will be made the active drive." När jag trycker continue får jag ett felmeddelande som säger att "The BitLocker Drive Preparation Tool failed to copy boot files. You made need to manually prepare your drive for BitLocker.". Vad kan jag göra? Ämnet redigerat av stenis, har förtydligat ämnet/rubriken Ämnet löst och låst av stenis, för vidare frågor starta en ny tråd Link to comment Share on other sites More sharing options...
Andreas Stenhall Posted January 17, 2008 Share Posted January 17, 2008 BitLocker kräver att du har en bootpartition där du har bootfilerna och sedan en separat partition för systemfilerna, dvs Windowskatalogen. När du installerar Vista ska du skapa och formatera en partition på 2GB först på disken och sedan skapa och formatera en till partition med resten där du väljer att installera Vista. Då läggs bootfilerna på den lilla partitionen och Vista installeras på den stora och du kommer att kunna använda BitLocker. Det kräver dock att du går in i gpedit.msc och ändrar en policy för att du ska kunna använda BitLocker utan TPM-chip. Det borde med en del trixande gå att skapa en mindre partition och göra den aktiv för att sedan låta BitLockerverktyget lägga de nödvändiga bootfilerna där. Jag har dock aldrig använt detta verktyg själv så jag vet inte alls hur det fungerar. Link to comment Share on other sites More sharing options...
nilsbalter Posted January 17, 2008 Author Share Posted January 17, 2008 Jag tänkte använda SWAP-partitionen (D) som aktiv - bootfiler, och det är det guiden försöker göra (automatiskt, fick inte välja partition). Policyn har jag nu ändrat. Det som konfunderar mig är varför verktyget inte kan flytta bootfilerna.. Jag ska testa att tömma D-partitionen och försöka igen. Link to comment Share on other sites More sharing options...
Andreas Stenhall Posted January 17, 2008 Share Posted January 17, 2008 Hur ser det ut i Diskhanteraren (Högerklicka Dator i Startmenyn och välj Hantera)? Vilken status har din D-partition (exempelvis System, boot osv)? Link to comment Share on other sites More sharing options...
nilsbalter Posted January 17, 2008 Author Share Posted January 17, 2008 Nu har jag äntligen lyckats! Jag tackar så mycket för hjälpen. Jag tog bort alla swap-filer från D-partitionen, formaterade den och körde sedan verktyget igen. Nu fungerar det som det ska! Tack igen! Link to comment Share on other sites More sharing options...
DanneManne Posted January 17, 2008 Share Posted January 17, 2008 Vad gör den där BittLocker grejen igentligen som är så bra? Link to comment Share on other sites More sharing options...
waxinator Posted January 17, 2008 Share Posted January 17, 2008 BitLocker krypterar dina diskar så att om datorn stjäls så är det omöjligt för andra att komma åt din data. Link to comment Share on other sites More sharing options...
Andreas Stenhall Posted January 17, 2008 Share Posted January 17, 2008 Lös mer om bitLocker här: http://www.alltomxp.se/index.php?option=co...0&Itemid=82 Låser tråden nu Link to comment Share on other sites More sharing options...
