__087 Posted December 10, 2007 Share Posted December 10, 2007 Hej. När jag försöker bränna ut saker på olika DVD-R skivor så får jag upp följande problem. (kolla bifogad fil) Stödjer inte min brännare DVD-R eller har någon något förslag på vad det kan vara? Tack på förhand. M.V.H // __087 Quote Link to comment Share on other sites More sharing options...
waxinator Posted December 10, 2007 Share Posted December 10, 2007 Denna artikel get en bra förståelse av hur det funkar med brännare och att strömmatningen kan vara boven bakom. http://club.cdfreaks.com/f92/dw1640-calibr...g-cd-rs-144692/ 9. I get a 'Power calibration error' or 'Calibration area (almost) full' error message. Why?Power Calibration is controlled by the recorder. Before any write operation, all recorders must do a 15 step power test to determine the optimum power for writing to the CD; this is called "Optimum Power Calibration"(OPC). During the write, it continues to do this test to get the best write throughout the whole CD; this is called "Running Optimum Power Calibration" (ROPC). This whole process is controlled by the recorder, though initiated by programs such as Nero. There is an area on the inner part of the CD for the test and test data info to be stored. You can use this area up to 999 times. If you receive the "Power calibration error" or "Power calibration area is (amost) full" error message, the cause will be either poor media, poor power, or a defective recorder. Please try the following solutions: * Update the firmware of your recorder. Please check the manufacturer's website for the latest version. * Try another brand of CD-R or CD-RW media. * Try different power connectors, and for recorders, do not share power with other devices. It needs its own power connector. If the error occurs with an external recorder, the power source in the chassis could be the cause. As a test, try to take the recorder out of the external chassis and connect it internal. * Try different configurations, such as taking the CD-ROM to the primary IDE bus as slave and have only the recorder connected to the secondary IDE bus as master. * Send the recorder in for service. Hmm, maybe you're right? I just disconnected my DW1640 from the PSU and tried the 109 and it's able to burn the ISO. I'm dissappointed now if it is my PSU, means I have to RMA the thing, hmm. Quote Link to comment Share on other sites More sharing options...
__087 Posted December 18, 2007 Author Share Posted December 18, 2007 Problemet är löst. Det verkade som att min brännare inte stödjer DVD-R skivor. M.V.H // __087 Quote Link to comment Share on other sites More sharing options...
patriot_chrille Posted December 18, 2007 Share Posted December 18, 2007 Har du ens testat att uppdatera din cd-läsare Quote Link to comment Share on other sites More sharing options...
