Process Explorer 14.11
Process Explorer v14.11: Process Explorer v14.11 includes the ability to configure network and disk activity icons in the tray.
http://blogs.technet.com/b/sysinternals/archive/2011/05/03/updates-zoomit-v4-2-process-explorer-v14-11-procdump-v3-04-and-mark-live-zero-day-malware-cleaning-with-the-sysinternals-tools.aspx
Länk till inlägg
  • 3 weeks later...
  • Svar 55
  • Created
  • Senaste svar
  • 1 month later...
Process Explorer v15 celebrates the release of the Sysinternals Administrator Reference and the upcoming 15th anniversary of Sysinternals. This major update to Process Explorer, a powerful tool for inspecting and controlling processes, threads, loaded DLLs, and more, adds GPU utilization and memory monitoring on Vista and higher. It also adds the ability to restart services, has a smaller memory footprint, and has visually cleaner performance graphs.
http://blogs.technet.com/b/sysinternals/archive/2011/07/18/updates-release-of-the-windows-sysinternals-administrator-s-reference-process-explorer-v15-listdlls-v3-1-new-utility-findlinks-v1-and-mark-to-speak-at-black-hat-us-2011.aspx
Länk till inlägg
  • 3 weeks later...
  • 2 weeks later...
Process Explorer v15.04: This release fixes several minor bugs, including a tooltip display bug and one that could result in a miscalculation of CPU usage on Windows 7 in the refresh immediately following the termination of a CPU-intensive process.
http://blogs.technet.com/b/sysinternals/archive/2011/09/01/updates-coreinfo-v3-debugview-v4-77-sdelete-v1-6-and-process-explorer-v15-04.aspx
Länk till inlägg
  • 3 weeks later...
  • 2 months later...
Process Explorer v15.1: This update of Process Explorer, a Task Manager replacement, adds support for new Windows 8 features by giving the processes hosting immersive applications a distinct highlight color, shows immersive application package names in process tooltips and as a new process view column, lists AppContainer and capability SIDs in the process security properties, and updates the GPU support to be compatible with Windows 8. Other enhancements include GPU memory counters with more descriptive labels, display of the logon session ID on the security properties, and reporting of suspended processes as suspended in the CPU usage column.
http://blogs.technet...vice-error.aspx
Länk till inlägg
  • 2 weeks later...
  • 4 weeks later...
Process Explorer 15.12
Process Explorer v15.12: This update to Process Explorer makes the search dialog asynchronous and reports the types of found items. It also fixes several bugs, including showing a small font when run after an older version, a bug in the restart-process functionality, working set columns not showing data, and again shows information about service processes when run from an unprivileged user account.
http://blogs.technet.com/b/sysinternals/archive/2012/01/13/updates-autoruns-v11-21-coreinfo-v3-03-portmon-v-3-03-process-explorer-v15-12-mark-s-blog-and-mark-at-rsa-2012.aspx
Länk till inlägg
  • 1 month later...
  • 3 months later...
Process Explorer v15.2: This major update to Process Explorer, a Task Manager replacement, merges Autoruns functionality by adding a new Autostart Location column and property to the process and DLL views that indicates where an image is configured to automatically start or load. It also adds .NET stack walking support to the thread stack dialog, adds a process timeline column that graphically depicts a process’s lifetime relative other processes, and uses the Windows 8 private ETW logger which enables better coexistence with other ETW-based tools.
http://blogs.technet...kill-v1-14.aspx
Länk till inlägg
  • 3 weeks later...
Process Explorer v15.21: This update fixes a bug related to the autostart functionality introduced in v15.2, a tooltip display bug, and a bug that prevented display of kernel stacks.
http://blogs.technet.com/b/sysinternals/archive/2012/06/28/updates-autoruns-v11-32-process-explorer-v15-21-process-monitor-v3-02-pskill-v1-15-rammap-v1-2.aspx
Länk till inlägg
  • 3 weeks later...
  • 2 months later...
Process Explorer v15.23: This update to Process Explorer adds the ability to view the process token of protected processes, fixes a bug that causes a crash when viewing thread stacks on Windows XP, and fixes a bug that causes a crash when running on Windows PE.
http://blogs.technet.com/b/sysinternals/archive/2012/10/03/new-psping-v1-0-updates-debugview-v4-8-process-explorer-v15-23-sigcheck-v1-81.aspx
Länk till inlägg
  • 4 months later...
Process Explorer v15.3: This major Process Explorer release includes heat-map display for process CPU, private bytes, working set and GPU columns, sortable security groups in the process properties security page, and tooltip reporting of tasks executing in Windows 8 Taskhostex processes. It also creates dump files that match the bitness of the target process and works around a bug introduced in Windows 8 disk counter reporting.
http://blogs.technet.com/b/sysinternals/archive/2013/02/04/updates-pendmoves-v1-2-process-explorer-v15-3-sigcheck-v1-91-zoomit-v4-42.aspx
Länk till inlägg
  • 3 months later...
Process Explorer v15.31: Process Explorer is a powerful process management utility. This update fixes a bug with copying text from the process properties dialog and adds an option to disable the heatmap display in the process view.
http://blogs.technet.com/b/sysinternals/archive/2013/06/04/updates-autoruns-v11-6-process-explorer-v15-31-process-monitor-v3-05-sigcheck-v1-92.aspx
Länk till inlägg
  • 1 month later...
Process Explorer 15.40
Process Explorer v15.40: Process Explorer, a Task Manager replacement, now shows WMI providers hosted in Wmiprvse processes (thanks to Mohamed Elghetany for contributions); includes an option that configures it to automatically run when you logon; and introduces a process view column that shows process DPI awareness support on Windows 8.1 systems.
http://blogs.technet.com/b/sysinternals/archive/2013/08/01/autoruns-v11-70-bginfo-v4-20-disk2vhd-v1-64-process-explorer-v15-40.aspx
Länk till inlägg
  • 5 months later...
Process Explorer 16.0
Process Explorer v16.0: Thanks to collaboration with the team at VirusTotal, this Process Explorer update introduces integration with VirusTotal.com, an online antivirus analysis service. When enabled, Process Explorer sends the hashes of images and files shown in the process and DLL views to VirusTotal and if they have been previously scanned, reports how many antivirus engines identified them as possibly malicious. Hyperlinked results take you to VirusTotal.com report pages and you can even submit files for scanning.
http://blogs.technet.com/b/sysinternals/archive/2014/01/29/updates-process-explorer-v16-0-psping-v2-01.aspx
Länk till inlägg
Process Explorer v16.01
Process Explorer v16.01: This release fixes a bug that could cause a crash when the VirusTotal column is added to the process view, and another that could cause a crash when verifying digital signatures.
http://blogs.technet.com/b/sysinternals/archive/2014/02/04/updates-process-explorer-v16-01-sigcheck-v2-02.aspx
Länk till inlägg
  • 1 month later...
Process Explorer v16.02: This minor update adds a refresh button to the thread’s stack dialog and ensures that the Virus Total terms of agreement dialog box remains above the main Process Explorer window.
http://blogs.technet.com/b/sysinternals/archive/2014/03/07/updates-process-explorer-v16-02-process-monitor-v3-1-psexec-v2-1-sigcheck-v2-03.aspx
Länk till inlägg
  • 4 months later...
Procexp v16.03: This release of Process Explorer, a process viewing and control utility, fixes several bugs, including one where moving the mouse over the information graphs could cause it to crash and another that could cause a crash when checking Virus Total results.
http://blogs.technet.com/b/sysinternals/archive/2014/08/08/new-sysmon-v1-0-updates-autoruns-v12-01-coreinfo-v3-3-procexp-v16-03.aspx
Länk till inlägg
Arkiverat
  • Liknande innehåll
    • Av JoWa
      Autoruns 10.0 har nu släppts.
      https://blogs.technet...nexplained.aspx
      Information och nedladdning
    • Av Andreas Stenhall
      Sysinternals (Microsoft) har släppt version 15 av Process Explorer. Bland nyheterna i verktyget som används som en mer avancerad aktivitetshanterare (Task Manager) finns övervakning av grafikprocessorer och minne. Andra nyheter innefattar att det är optimerat för att ta så lite resurser som möjligt, ett renare gränssnitt och att det nu är möjligt att starta om tjänster inifrån verktyget.
      Ladda hem Process Explorer 15
