mussi Postad November 14, 2007 Dela Postad November 14, 2007 Hej! Har problem med att få igång buffern på min brännare. lyckades bränna en skiva i helgen men nu funkar det inte, läste runt och folk skrev att det inte fanns problem med Nero 8 men den funkar fortfarnde inte. Bifogar en log så kanske nån kan hjälpa mig Mustafa Sak Hem 8***-4225-1105-****-5000-0021-**** Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 8.1.1.0 Internal Version: 8, 1, 1, 0 Recorder: <BENQ DVD DD DW1620> Version: B7W9 - HA 1 TA 0 - 8.1.1.0 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default CD-ROM: <BENQ DVD DD DW1620 >Version: B7W9 - HA 1 TA 0 - 8.1.1.0 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG HD501LJ atapi Port 0 ID 1 DMA: On CdRomPeripheral : BENQ DVD DD DW1620 atapi Port 1 ID 0 DMA: On CdRomPeripheral : ATAPI CDRW 52X32 atapi Port 1 ID 1 DMA: On CdRomPeripheral : YB1982C SFU042O 1.0 adfvzw0p Port 2 ID 0 DMA: Off === CDRom-Device-Map === BENQ DVD DD DW1620 D: CdRom0 ATAPI CDRW 52X32 E: CdRom1 YB1982C SFU042O F: CdRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 2047MB (2096620kB) Free physical memory: 1591MB (1629568kB) Memory in use : 22 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 14.11.2007 ISO compilation 21:41:54 #1 Text 0 File SCSIPTICommands.cpp, Line 450 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 21:41:54 #2 Text 0 File Isodoc.cpp, Line 6671 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 21:41:54 #3 ISO9660GEN -11 File Geniso.cpp, Line 3347 First writeable address = 0 (0x00000000) 21:41:54 #4 Text 0 File Burncd.cpp, Line 3530 Turn on Disc-At-Once, using DVD media 21:41:54 #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142 FS Settings: using validator 'CUDFSettingsValidatorDVD' ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical' Changing UDF revision from '1.02' to '1.02' 21:41:54 #6 Text 0 File DlgWaitCD.cpp, Line 307 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 2147519 (477:13.44, 4194MB) 21:41:54 #7 Text 0 File DlgWaitCD.cpp, Line 319 Write in overburning mode: NO (enabled: CD) 21:41:54 #8 Text 0 File DlgWaitCD.cpp, Line 2972 Recorder: BENQ DVD DD DW1620, Media type: DVD-R Disc Manufacturer ID: <MCC 02> <RG20 > Disc Application Code: 64, Disc Physical Code: 193 21:41:54 #9 Text 0 File DlgWaitCD.cpp, Line 493 >>> Protocol of DlgWaitCD activities: <<< ========================================= 21:41:54 #10 Text 0 File ThreadedTransferInterface.cpp, Line 785 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2147520 (2147520) = #2147520/477:13.45 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2147520 blocks [D: BENQ DVD DD DW1620] -------------------------------------------------------------- 21:41:54 #11 Text 0 File ThreadedTransferInterface.cpp, Line 986 Prepare [D: BENQ DVD DD DW1620] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4398120960, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 1 | 0x41 | 2147520 | 0 | 0x00 2147520 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 21:41:54 #12 Text 0 File SCSIPTICommands.cpp, Line 240 SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME 21:41:54 #13 Text 0 File Burncd.cpp, Line 4316 Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB) 21:41:54 #14 Phase 24 File dlgbrnst.cpp, Line 1764 Caching of files started 21:41:55 #15 Text 0 File Burncd.cpp, Line 4435 Cache writing successful. 21:41:55 #16 Phase 25 File dlgbrnst.cpp, Line 1764 Caching of files completed 21:41:55 #17 Phase 36 File dlgbrnst.cpp, Line 1764 Burn process started at 2.4x (3 324 KB/s) 21:41:55 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2735 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 21:41:55 #19 Text 0 File DVDR.cpp, Line 3245 Recording mode: Sequential Recording Mode 21:41:55 #20 Text 0 File DVDR.cpp, Line 3401 Start write address at LBA 0 DVD high compatibility mode: Yes 21:41:55 #21 Text 0 File Cdrdrv.cpp, Line 10026 ---- Disc Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) Outer Limit of Data Recordable Area: 0 h Data in Burst Cutting Area (BCA) does not exist Revision number of maximum recording speed: - Revision number of minimum recording speed: - Revision number table of recording speed: - - - - - - - Class: 0, Extended part version: 0 Start PSN of the Extra Border Zone: 0 h Start PSN of Physical format information blocks in Extra Border Zone: 0 h Media Specific [16..783]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 21:41:55 #22 Text 0 File ThreadedTransfer.cpp, Line 268 Pipe memory size 83836800 21:42:27 #23 SPTI -1135 File SCSIPassThrough.cpp, Line 181 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 12 00 00 00 00 0C Buffer x093b0040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21:42:27 #24 CDR -1135 File Writer.cpp, Line 306 Write error D: BENQ DVD DD DW1620 21:42:27 #25 Text 0 File DVDR.cpp, Line 3803 EndDAO: Last written address was -1 (FFFFFFFFh) 21:42:27 #26 Phase 38 File dlgbrnst.cpp, Line 1764 Burn process failed at 2.4x (3 324 KB/s) 21:42:27 #27 Text 0 File SCSIPTICommands.cpp, Line 287 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 21:42:30 #28 Text 0 File Cdrdrv.cpp, Line 11276 DriveLocker: UnLockVolume completed 21:42:30 #29 Text 0 File SCSIPTICommands.cpp, Line 450 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLMSoftwareMicrosoftWindows NTCurrentVersionWinLogonAllocateCDROMs : 0 (Security Option) Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
waxinator Postad November 14, 2007 Dela Postad November 14, 2007 Är du säker på att du har buffer-problem ? Enligt loggen så får du efter 33 sekunders bränning, felet "KEY_MEDIUM_ERROR" och "Write error". Burn process failed at 2.4x (3 324 KB/s) Detta pekar på medium fel (dålig skiva). Enligt din DVD's BIOS version så har du den senaste (från 2004) B7W9. Ser du sedan på "Disc Manufacturer ID: <MCC 02> <RG20>" så kan man läsa på nätet att just skivorna MCC02 är lågkvalliteskivor. Imation = MCC02 Prodisc = MCC02 Verbatim = MCC02 http://www.supermediastore.com/what-dvd-media-buy.html Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
mussi Postad November 14, 2007 Författare Dela Postad November 14, 2007 Jo visst är det budget skivor ;D Men bränning skall väl gå igång? Buffern fylls inte ens utan det blir direkt fel. Infiniti skivor är det. Så det är alltså inga problem med brännaren utan skivorna? Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
waxinator Postad November 14, 2007 Dela Postad November 14, 2007 Buffern fylls inte ens utan det blir direkt fel Du har enligt loggen WriteBufferSize: 83MB http://www.nero.com/eng/support-nero8-manu...ml?language=sve Du kan prova att sänka brännings hastigheten och på så vis bränna skivan hårdare. Visserligen är nuvarande 2,4x bränning inte någon hög hastighet men men... Förr brände de utan buffer och det gick bra så länge som inget annat jobbigt program gick samtidigt. Med andra ord, bufferten är inget krav för lyckad bränningen. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
plun Postad November 14, 2007 Dela Postad November 14, 2007 Gjorde en snabbkoll själv på firmware gurusarnas sidor. http://forum.rpc1.org/dl_firmware.php?download_id=1905 http://tdb.rpc1.org/#DW1620 Verkar inte finnas nyare så det är nog kört med de här skivorna. Ev fixar Dangerous Brother firmwaret fler skivor men troligen inte. Lägre hastighet är nog ända sättet att testa. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
mussi Postad November 25, 2007 Författare Dela Postad November 25, 2007 Hur skulle det funka om jag skulle köra G-drivrutinerna? Eller tror ni att det är möjligt att flasha om spelaren till nåt annat via den här länken. http://club.cdfreaks.com/f92/bqflasher-149980/ Enligt dom jag köpte skivorna så är kvalitén 97 med 1640, borde la inte vara så stor skillnad på en 1620 :/ http://www.sweburn.com/forum/viewtopic.php?t=8 vågar man testa att flasha om den? Och hur skall jag gå tillväga, förstår inte riktigt vad han snackar om på den första länken. Tack för all hjälp Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
plun Postad November 25, 2007 Dela Postad November 25, 2007 Den länkas över hit till howton http://club.cdfreaks.com/f92/benq-how-flasher-171380/ All flashning gör man på egen risk.... Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
mussi Postad November 25, 2007 Författare Dela Postad November 25, 2007 Jag skippar nog det där. Blev medlem och kollade genom alla bilder lite snabbt, verkar ganska avancerat och jag vill inte förstöra min brännare, trots att den inte funkar alltför bra ;D Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
plun Postad November 25, 2007 Dela Postad November 25, 2007 Jag skippar nog det där. Blev medlem och kollade genom alla bilder lite snabbt, verkar ganska avancerat och jag vill inte förstöra min brännare, trots att den inte funkar alltför bra ;D Njau... det är lte rörigt eftersom de visar flera sätt att flasha Det du kollat in görs då så här: http://club.cdfreaks.com/f92/benq-how-flas...80/#post1326804 Sen om man flashar sönder sin brännare så är det ju inga större pengar numera.... Har du provat att bara sänka hastigheten som vi var inne på tidigare i tråden. Som "MrWax" skrev så går det alldeles för fort för de här skivorna. Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
mussi Postad November 25, 2007 Författare Dela Postad November 25, 2007 Kört på 2.4 vilket är det lågnsammate och det funkade inte, varken vanligt eller i felsäkert läge... :/ Får nog ta och köpa mig en ny brännare snart Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
plun Postad November 25, 2007 Dela Postad November 25, 2007 Kollade lite på firmware och du kör ju B7W9 Även med en crossflash så blir det samma firmwareversion. Klart/oklart om en crossflashad brännare klarar mer. Blir själv inte riktigt klok på det här. 8) Hursomhelst så är det ju Dangerous brothers firmware eller det här http://dvd-rw.hoppy.tk/dvd-rw/benq/1620/ benq o philips är en röra....ska du ändå köpa en ny så flasha.... Om det misslyckas så köp en NEC... Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
