Chrome Beta & Chromium
Mats H
  • 1 månad senare...
Kanske en dum fråga, men här kommer den ändå.
Förr hade man en stabil version, en beta och en developer. Alla med tre olika versionsnummer. (första siffrorna före första punkten.
Nu när ver 11 släpptes som stabil så är fortfarande 12:an developer. Borde man inte ha lyft upp developer till ver 13 och gjort om 12:an till beta?
  • 4 veckor senare...
  • 3 veckor senare...
Stable channel: This channel has gotten the full testing and blessing of the Chrome test team, and is the best bet to avoid crashes and other issues. It's updated roughly every two-three weeks for minor releases, and every 6 weeks for major releases.
Beta channel: If you are interested in seeing what's next, with minimal risk, Beta channel is the place to be. It's updated every week roughly, with major updates coming ever six weeks, more than a month before the Stable channel will get them.
Dev channel: Want to see what's happening quickly, then you want the Dev channel. The Dev channel gets updated once or twice weekly, and it shows what we're working on right now. There's no lag between major versions, whatever code we've got, you will get. While this build does get tested, it is still subject to bugs, as we want people to see what's new as soon as possible.
Canary build: Canary builds are the bleeding edge. Released daily, this build has not been tested or used, it's released as soon as it's built. Because there's no guarantee that it will even run in some cases, it uses it's own profile and settings, and can be run side by side another Chrome channel. By default, it also reports crashes and usage statistics to Google (you can disable this on the download page).
Chrome Release Channels
Med direkt menar jag bara att det är en direktlänk till installationsprogrammet (och inte till en sida).
  • 2 veckor senare...
  • 1 månad senare...
Att hämta ChromePlus är ingen rolig historia. Hämtningslänkarna leder till brothersoft.com, och efter ett par klick där får man ned Brothersoftdownloader_for_ChromePlus.exe istället för det önskade programmet. :angry:
Hämta hellre från Softpedia: http://www.softpedia.com/get/Internet/Browsers/ChromePlus.shtml Portabel: http://www.softpedia.com/get/Internet/Browsers/Portable-ChromePlus.shtml
Kör man någon av Chrome-varianterna kan man visa Brothersoft vad man tycker om dylika fasoner, genom att helt enkelt blockera dom i alla framtida Googlesökningar. Tillägget Personal Blocklist ser till så att alla träffar på Brothersoft-domänen filtreras bort i sökresultaten.
Om man vill, kan man faktiskt blockera vilka domäner som helst med tillägget... ;)
Redigerad av e-son
